У кого в авто двигатель 2.0i APK & AQY?
Skams Немає
Приєднався: Jan 2019
Обухів
Skoda Octavia Combi 2001 2.0 AQY Elegance
Повідомлення: #511
21-03-2019 15:15 RE: У кого в авто двигатель 2.0i APK & AQY?
Мож кому поможет, спецификации для наших двигателей, чтобы потом сравнивать с показателями ваг кома на Вашем авто.
; VAG-COM label file
; Skoda Octavia (1U) / VW Bora/Golf (1J) / VW New Beetle (9C)
; component: Engine (#01) — APK/AQY
; p/n: 06A 906 018 ?
; includes measuring blocks and coding
; This file is part of a redirection package,
; make sure you have all of the following files.
; 06-01.LBL
; 06A-906-018-AQY.LBL (2.0l E @ 115 HP — APK/AQY)
; created on 19/Apr/2005 by Sebastian Stange (sebastian@ross-tech.com)
; last modification: 18/April/2005
; ready for VAG-COM 405.0 and above
; coding information
C0,Engine (APK/AQY) Coding
C1,APQ/AQY (< MY 2000)
C2,
C3,00000 — Manual Transmission with ABS
C4,00001 — Automatic Transmission with ABS
C5,
C6,APQ/AQY (M> 2000 >)
C7,
C8,000?x: CAN-Databus
C9,+1 — Anti-Blocking-System (ABS)
C10,+2 — Airbag
C11,
C12,00xx?: Transmission
C13,1 — 5-Speed Manual Transmission
C14,3 — Automatic Transmission
; measuring block information
001,0,Basic Functions
001,1,Engine Speed, , Specification: 740…820 RPM
001,2,Coolant, Temperature, Specification: 85.0…110.0 °C
001,3,Lambda, Controller, Specification: -10.0…+10.0
001,4,Basic Setting, Requirements, see labelfile
; xxxxx1 — Coolant temperature below 80 °C
; xxxx1x — Engine speed below 2000 RPM
; xxx1xx — Throttle valve closed
; xx1xxx — Lambda regulation correct
; x1xxxx — State of idle
; 1xxxxx — A/C system compressor deactivated
002,0,Basic Functions (Mass Air Flow)
002,1,Engine Speed, , Specification: 740…820 RPM
002,2,Engine Load, , Specification: 15.0…35.0 %
002,3,Injection, Timing, Specification: 2.0…5.5 ms
002,4,Intake Air Mass, , Specification: 2.0…5.0 g/s
003,0,Basic Functions (Mass Air Flow)
003,1,Engine Speed, , Specification: 740…820 RPM
003,2,Intake Air Mass, , Specification: 2.0…5.0 g/s
003,3,Throttle Drive, Angle Sensor 1,for EPC (G187) | Specification: 0…6 °<
003,4,Ignition, Timing Angle, Specification: 0…12 °BTDC
004,0,Basic Functions
004,1,Engine Speed, , Specification: 740…820 RPM
004,2,Voltage Supply, , Specification: 12.0…14.5 V
004,3,Coolant, Temperature, Specification: 80…110 °C
004,4,Intake Air, Temperature, Specification: -45.0…+108.5 °C
005,0,Basic Functions
005,1,Engine Speed, , Specification: 740…820 RPM
005,2,Engine Load, , Specification: 15.0…35.0 %
005,3,Vehicle Speed, , Specification: 0 km/h
005,4,Load Status, , Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
006,0,Basic Functions
006,1,Engine Speed, , Specification: 740…820 RPM
006,2,Engine Load, , Specification: 15.0…35.0 %
006,3,Intake Air, Temperature, Specification: -45.0…+108.5 °C
006,4,Altitude, Correction Factor
010,0,Ignition
010,1,Engine Speed, , Specification: 740…820 RPM
010,2,Engine Load, , Specification: 15.0…35.0 %
010,3,Throttle Drive, Angle Sensor 1,for EPC (G187) | Specification: 0…6 °<
010,4,Ignition, Timing Angle, Specification: 0.12 °BTDC
014,0,Ignition (Misfire Recognition)
014,1,Engine Speed, , Specification: 740…820 RPM
014,2,Engine Load, , Specification: 15.0…35.0 %
014,3,Misfire, (total), Specification: 0…5
014,4,Misfire, recognition, Specification: active | Display Range: active/inactive
022,0,Ignition (Knock Control — Cyl 1 && 2)
022,1,Engine Speed, , Specification: 740…6800 RPM
022,2,Engine Load, , Specification: 0.0…100.0 %
022,3,Cylinder 1 Ignition, Angle Delay, Specification: 0.0…15.0 °CA
022,4,Cylinder 2 Ignition, Angle Delay, Specification: 0.0…15.0 °CA
023,0,Ignition (Knock Control — Cyl 3 && 4)
023,1,Engine Speed, , Specification: 740…6800 RPM
023,2,Engine Load, , Specification: 0.0…100.0 %
023,3,Cylinder 3 Ignition, Angle Delay, Specification: 0.0…15.0 °CA
023,4,Cylinder 4 Ignition, Angle Delay, Specification: 0.0…15.0 °CA
030,0,Oxygen Sensor Status
030,1,Bank 1,Sensor 1,Specification: 111
; 1xx — Lambda sensor heating on
; x1x — Lambda sensor ready
; xx1 — Lambda regulation active
030,2,Bank 1,Sensor 2,Specification: 111
032,0,Lambda Regulation
032,1,Lambda (Idle), Self-Adaptation, Specification: -10…+10 %
032,2,Lambda (Partial), Self-Adaptation, Specification: -10…+10 %
033,0,Lambda Regulation (befor Catalyst)
033,1,Bank 1,Lambda Control, Specification: -10.0…+10.0 %
033,2,Bank 1 Voltage, of Oxygen Sensors, Specification: 0.00…1.00 V
034,0,Lambda Regulation (befor Catalyst — Basic Setting: Aging Check)
034,1,Engine Speed, , Specification: 2200…2800 RPM
034,2,Catalytic Converter, Temperature, Specification: min. 352 °C
034,3,Period, Duration Sensor, Specification: max. 2.2 s
034,4,Result, Lambda Aging, Display Range: Test ON/Test OFF/B1-S1 not OK/B1-S1 OK
036,0,Lambda Regulation (after Catalyst)
036,1,Bank 1 Sensor 2,Voltage, Specification: 0.00…1.00 V
036,2,Result, Lambda Availability, Display Range: Test ON/Test OFF/B1-S2 not OK/B1-S2 OK
037,0,Lambda Regulation (after Catalyst — Basic Setting)
037,1,Engine Load, , Specification: 15…35.0 %
037,2,Bank 1 Sensor 2,Voltage, Specification: 0.00…1.00 V
037,3,Lambda Regulator, Dwell Period, Specification: -1200…+1200 ms
037,4,Result, , Specification: Test ON/Test OFF/Sys. OK/Sys. not OK
041,0,Lambda Regulation (Lambda Probe Heating)
041,1,Resistance, Bank 1 Sensor 1,Specification: 6.4…47.5 Ohm
041,2,Heater Condition, , Specification: Htg.bC.ON
041,3,Resistance, Bank 1 Sensor 2,Specification: 6.4…47.5 Ohm
041,4,Heater Condition, , Specification: Htg.aC.ON
046,0,Lambda Regulation (Basic Setting: Conversion Test)
046,1,Engine Speed, , Specification: 2800…3200 RPM
046,2,Catalytic Converter, Temperature, Specification: min. 352 °C
046,3,Amplitude, Behavior, Specification: 0.00…0.55
046,4,Result Catalytic, Conversion, Pre-Catalytic Converter (Display Range: Test ON/Test OFF/CatConvB1 not OK/CatConvB1 OK)
050,0,Speed Regulation
050,1,Engine Speed, , Specification: 740…820 RPM
050,2,Engine Speed, (specified), Specification: 780 RPM
050,3,Condition, of A/C system, Display Range: A/C-High / A/C-Low
050,4,Operating condition, of A/C Compressor, Display Range: Compr.ON/Compr.OFF
054,0,Speed Regulation
054,1,Engine Speed, , Specification: 740…820 RPM
054,2,Load Status, , Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
054,3,Sender 2 for, Acc. Pedal Pos., G79 (Specification: 0…6 °<)
054,4,Throttle Drive, Angle Sensor 1,for EPC (G187) | Display Range: 0…100 %
055,0,Speed Regulation
055,1,Engine Speed, , Specification: 740…820 RPM
055,2,Idle Regulator, , Specification: -2.00…+2.00 g/s
055,3,Idle Stabilization, Self-Adaptation, Specification: -1.50…+.150 g/s
055,4,Load Status, , see labelfile
; -1xx — Air conditioning system switched on
; -x1x — Gear engaged
; -xx1 — Air conditioner compressor switched on
056,0,Speed Regulation
056,1,Engine Speed, , Specification: 740…820 RPM
056,2,Engine Speed, (specified), Specification: 780 RPM
056,3,Idle Regulator, , Specification: -2.00…+2.00 g/s
056,4,Load Status, , see labelfile
060,0,Speed Regulation (Basic Setting: Throttle Body Adaptation)
060,1,Throttle Drive, Angle Sensor 1,for EPC (G187) | Specification: 0…6 °<
060,2,Throttle Drive, Angle Sensor 2,for EPC (G18Cool | Specification: 0.0…5.0 V
060,3,Load Status, , Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
060,4,Result, Throttle Valve Adp., Display Range: ADP runs/ADP OK/ADP ERROR
066,1,Cruise Cntrol System
066,2,Brake switch, clutch and CCS, Specification: 1000
; 1xxx — Cruise control system active
; x1xx — Clutch depressed (always 1 in automatic transmission)
; xx1x — Brake depressed (brake pedal switch)
; xxx1 — Brake depressed (brake light switch)
066,3,Specified Speed
066,4,CCS Control, Positions, Specification: 0000
; 1xxx — CCS slide handle on RES or RES button on multi-function steering wheel pressed
; x1xx — SET button pressed
; xx1x — CCS slide handle on OFF (not engaged or engaged)/OFF button on multi-function steering wheel pressed
; xxx1 — CCS slide handle on OFF
070,0,Emission Reduction (TEV — Basic Setting)
070,1,Evap. Emissions, Sol. Valve (Open), Specification: 0…100 %
070,2,Lambda Regulator, Deviation, Specification: -7.8…+7.8 %
070,3,Evap. Emissions, Sol. Valve (Flow), Specification: 0.00…0.33 g/s
070,4,Result, Evap. Emissions, Display Range: Test ON/Test OFF/TEV OK/TEV not OK
077,0,Emission Reduction (Basic Setting)
077,1,Coolant, Temperature, Specification: 85.0…110.0 °C
077,2,Lambda Regulator, Deviation, Specification: max. 25 %
077,4,Result, , Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK
098,0,Speed Regulation (Basic Setting: Throttle Body Adaptation)
098,1,Throttle Drive, Angle Sensor 1,for EPC (G187) | Specification: 0…6 °<
098,2,Throttle Drive, Angle Sensor 2,for EPC (G18Cool | Specification: 60.0…90.0 %
098,3,Load Status, , Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
098,4,Result, Throttle Valve Adp., Display Range: ADP runs/ADP OK/ADP ERROR
099,0,Lambda Regulation (Basic Setting)
099,1,Engine Speed, , Specification: 740…820 RPM
099,2,Coolant, Temperature, Specification: 80.0…110.0 °C
099,3,Lambda Regulator, (before catalyst), Specification: -10.0…+10.0 %
099,4,Status Lambda, Regulation, Display Range: ON/OFF
100,1,Readiness-Bits, , Specification: 00000000
; 0xxxxxxx — Exhaust Gas Recirculation (EGR)
; x0xxxxxx — Sensor heater
; xx0xxxxx — Oxygen sensors
; xxx0xxxx — A/C system
; xxxx0xxx — Secondary Air Injection (AIR) system
; xxxxx0xx — Activated charcoal system
; xxxxxx0x — Catalytic converter heater
; xxxxxxx0 — Catalytic converter
100,2,Coolant, Temperature, Specification: 85.0…110.0 °C
100,3,Time since, Engine Start
100,4,OBD-Status
Я на Drive2
(Востаннє це повідомлення було змінене: 21-03-2019 16:10 Skams.)
Pasa Немає
Приєднався: Sep 2015
Мариуполь
Skoda Octavia 1U2 2.0 APK 2004г.в.
Skype IDpasa0903
Повідомлення: #512
04-07-2019 22:33 RE: У кого в авто двигатель 2.0i APK & AQY?
Кто менял лямбду, что ставили?
Есть подозрение что моей хана, как вычислить ваг комом?
Буду длогодарен за подсказки, может кто прошел через этот этап?
garikkr Немає
Приєднався: Dec 2013
Kryviy Rih
Octavia Tour 2.0 apk
Повідомлення: #513
30-10-2020 00:06 RE: У кого в авто двигатель 2.0i APK & AQY?
(04-07-2019 22:33)Pasa :  Кто менял лямбду, что ставили?
Ставил ВАЗовскую, уже несколько лет работает, всё в норме, цена около 600 грн
[Зображення: eV2ORmU.gif]
  Дергается авто. может у кого была такая проблема RoCor 5 3 924 08-06-2019 11:47
Останнє: RoCor
  Низкое давление в рампе. Троит двигатель 2.0 Тди. Двигатель СААС egorka 5 6 053 28-01-2019 20:45
Останнє: egorka
  На заметку тем у кого авто старше 7-8 лет Misan 20 7 809 07-06-2016 13:57
Останнє: Phoenix87
  У кого фаба 1,4/101 hp двигатель BBZ CNH 30 14 443 05-04-2015 15:19
Останнє: Crack9mm
  У кого двигатель AGU требуется помощь vetalkiev 4 2 596 03-07-2014 11:59
Останнє: vetalkiev
  Авто из салона-у кого сколько КМ было? Михаилл 98 33 146 02-01-2008 14:11
Останнє: Popov
